32098 32098 is offline
Default help with uninstalling of programs - 06-15-2009, 07:07 PM
I was upgrading from a 2gb to 16gb sdhc card and used the hitachi driver to have it appear as fixed. As I attempted to reinstall my Garmin GPS and Quicken programs onto the 16gb card, I am encountering problems with the uninstallation of the programs that were on the 2gb card. I went through the remove programs in the control panel as well as trying Revo Uninstaller. When I put the Quicken disc into the external drive it trys to uninstall but closes saying uninstallation has failed. Is there any around this? Or will I have to re-install XP in my "spare time"? Any help is appreciated...
Default 06-15-2009, 08:27 PM
danmanx danmanx is offline
danmanx's Avatar
Default 06-15-2009, 11:09 PM
You can always delete the files manually first and then delete the uninstall lines in add/remove with ccleaner.
Believe it or not, this will remove most of the files, as long as they haven't installed in any directories you're not aware of.
Dell Inspiron Mini 9 / Custom XP Pro SP3 / 2GB Mushkin RAM / 4GB Stock SSD / Mini BT USB Dongle / 16GB Class 6 SDHC
Default 06-15-2009, 11:33 PM
There's more to it than that - if you simply delete the registry entries for add/remove, you leave dangling potentially hundreds of entries that may interfere with future installs.
Default 06-16-2009, 01:39 AM
Thanks to all, the windows install cleanup utility and ccleaner solved the issues. Love my mini!
« 16G SSD is enough for dual-boot XPH/OSX | GMA950 vs 500: Dell Mini 10 Video Performance »
