EricsVostro EricsVostro is offline
Default Using Dell Mini 9/Vostro a90 with a Projector - 06-13-2009, 11:31 PM
One of the main reasons I wanted a Mini Mac was to do presentations while traveling.
I know that with the current driver (extension) that mirroring doesn't work, but extending the desktop to an external device does. I also have read that using the old extension supports mirroring to two monitors, but can be flaky.
Is anyone successfully connecting to and using projectors?
Thanks,
E
Dell Vostro a90, 16GB SSD, 32GB SD Card, 2GB RAM running OS X 10.5.7
My first "Mac" after 20 years on Windows and loving it
robbneu robbneu is offline
Default 06-16-2009, 12:14 PM
While I haven't connected my Vostro to a projector yet, I have plugged it into a couple of monitors and have been pretty pleased with the output from the A90. Its a good, stable image, that doesn't flicker or pulsate or otherwise do anything distracting. My only concern with using the Vostro/Mini 9 to run projectors and presentations would be the limited output resolutions. At least in Ubuntu, it seems like my Vostro is limited to 1024x768 (I think), while adequate, might not be the best format for certain types of presentations.
If you're doing fairly simple presentations, I suspect it'll be fine. If you're presenting really complex images or data and need a much sharper image, you might run into trouble with the Mini 9. That being said, I really can't imagine needing to project something that detailed.
It should do fine!
BKR2879 BKR2879 is offline
BKR2879's Avatar
Default 06-16-2009, 05:01 PM
No projector yet (though we do have one here at work), but I did plug my A90 into a 24" Gateway monitor and it drove 1920x1200 just fine under OSX.
Image wasn't super sharp over standard crappy VGA but it was certainly usable.
DELL Vostro 1720 - 2.4Ghz - 4GB - 500GB - Windows 7
DELL XPS M1330 - 2.4Ghz - 4GB - 500GB - Windows 7
DELL Vostro A90 - 2GB - 64GB SSD - OSX
danmanx danmanx is offline
danmanx's Avatar
Default 06-16-2009, 08:38 PM
Here's an answer for you. The Mini 9 works great with a projector. I used a 640x480 projector and was happy it worked great. And yes, it mirrored the mini's screen and I used it to load/unload games on my wall.
Dell Inspiron Mini 9 / Custom XP Pro SP3 / 2GB Mushkin RAM / 4GB Stock SSD / Mini BT USB Dongle / 16GB Class 6 SDHC
Cool 06-19-2009, 02:25 PM
Thanks. But what about higher res projectors like the ones I'm likely to encounter at hotels and other speaking venues?
E
Default 06-19-2009, 02:27 PM
It should do fine!
Thanks for the input, no really detailed images. I've got an old Samsung 17" LCD Monitor that I'll plug in for starters.
E
Default 06-23-2009, 10:33 PM
Interesting I just plugged it into a Samsung Sync Master 172n and it kicks both the Vostro and Samsung screen into a "test pattern" looking screen.
Did you long any drivers or just a standard OS X 10.5.7 install?
Thanks
lswartz lswartz is offline
Default 06-27-2009, 11:40 PM
We used open office presentation on a DLP with out a problem. A USB mouse with fresh batteries makes it an easy presentation tool. Everyone else was lugging around notebooks with their eyes on my Mini 9.
psyopper psyopper is offline
Default 06-28-2009, 01:51 AM
E
Most professional speaking venues will use 1024x768 unless they tout high-res, which most don't because the A/V industry is waiting for switcher vendors to get HDCP certification on their devices. Don't get me started on the headache that HDCP is to A/V techs - I am one and it drives me insane at times.
I would recommend plugging your vga out into any available monitor and driving it at 1024x768 to test it. I don't know if you know much about OSX so take no offense when I tell you how to set up multiple monitors.
While using the following directions you should swing a dead chicken 10 times counter clockwise over your head, then swing it 10 more time clockwise over your head (the order is important, don't deviate) while chanting "Please God, just work" repeatedly until complete.
1. Connect your external device (projectors are just teeny tiny monitors with microscopes attached to them)
2. Apple Menu - System Preferences - Displays
3. Click the Detect Displays button.
4. If your external display is detected you will see a new button marked "Arrangement". Click it and select Mirror
5. Set the output to 1024x768
http://shop.psyopper.com
Red face 07-05-2009, 01:30 PM
I'm very new to OS X so clearly no offense taken, in fact thanks for the level of detail.
I'll give this shot once I'm back in town again
E
dell mini 9, os x, presentations, vostro a90
« Usb power consumption?? | asus, Pentium t3200 160gb 2gb os; vista premium. intel dual-core »
