Post AIM question - 06-06-2009, 12:22 AM
So i downloaded AIM on my mini 9, and my friend says that AIM is not a great program for the mini... I dont seem to have a lot of problems with it, but im nervous that he's going to be right. does anyone else use AIM on theirmini's and if so, is it working ok?
Default 06-06-2009, 01:03 AM
The major thing I have against AIM is that it loads you with ads. I use Trillian instead - not only does it work well, but one program also connects with Yahoo and MSN.
Default 06-06-2009, 01:22 AM
yeah i have another client that i use for chat that can use all of the chat programs as well, but it doesnt support video chat with aim. i usually use skype but some of my friends dont use that so i download aim.
does trillion support video chat?
Default 06-06-2009, 10:36 AM
Trillian Pro, which is not free, supports video. I don't know of a reason why AIM should not work for you. It's easy to try it, right?
sharksfan's Avatar
Default 06-08-2009, 06:45 AM
I don't use AIM on mine. I've used Yahoo with video chat and IM Live but IM LIve doesn't support video chat.
Dell Mini 9 | Mac OS X 10.5.7 | 2 GB RAM | RunCore 64
BIOS A05 | 16 GB SD | USB Legacy Mode: OFF | BT |DellEFI 1.2a5 | 1.3mp WC
danmanx's Avatar
Default 06-08-2009, 03:34 PM
There's also a version of AIM Express on the website if you don't want to install it. As others stated, AIM has ads. I'm sure you'll be fine with the regular version though.
Dell Inspiron Mini 9 / Custom XP Pro SP3 / 2GB Mushkin RAM / 4GB Stock SSD / Mini BT USB Dongle / 16GB Class 6 SDHC
MoInSTL's Avatar
Default 06-08-2009, 04:06 PM
I use Pidgin Portable. Supports a ton of chat clients, has a small footprint and is Open Source (free).
aim
« Vostro A90 owner with SSD question | i want to delete a partition »
