dollarbill22 dollarbill22 is offline
dollarbill22's Avatar
Post Plug-in network not working - 05-29-2009, 10:39 PM
after my wifi wasn't working i tried to use direct internet connection.
I tried to change my settings and that didn't work and i thought i used it only my direct connection once before my update. If anybody nows how to fix that please help.
MINIRUN47 MINIRUN47 is offline
Default 05-29-2009, 10:49 PM
after you do the terminal commands eveything should be back to normal just leave the network cable plugged in .....
Ice Blue 32gb ssd 2gb ram OSX .3mp camera....
Default 05-29-2009, 10:53 PM
i changed some things and i tried to put the ip adress in and that didnt work.
Default 05-29-2009, 10:55 PM
just do what i said above and everything will go back to the way it was before your update failed then rerun your updates and you should have everything back ok?
Default 05-30-2009, 08:32 AM
yea it worked now my wifi is working and im posting on my dell mini
Obsidian black 8gb ssd 512 ram ubuntu .3 mp camera....
Thumbs up 05-30-2009, 04:06 PM
sweet! glad it worked! now after every update do those terminal commands and you should be fine!
« Ordering a Dell Mini 9, what's Dell up to? | How do I install Windows 7 on current Ubuntu machine »
