View Poll Results:
0 0%
alpha10 alpha10 is offline
Question Which Wireless Card ? - 05-20-2009, 11:59 AM
Should I choose, I just want a good performance and battery life.
Thanks
Default 05-20-2009, 01:53 PM
Which OS are you running? If it's Windows or Linux, the Intel 5100 is a good choice. If it's OS X, then skip the Intels. Oh, the 5300 also does wireless b though the specs tend to gloss over that.
hircus hircus is offline
Default 05-21-2009, 02:26 AM
I just upgraded to 5100 myself, on Linux. I'd recommend skipping the 5300 as it needs 3 antennas to go full speed anyway, and the Mini 9 only has 2 (you have to rig the third yourself).
Interestingly, has anyone noticed any temperature difference between the default Broadcom and the Intel cards? I forgot to check the temperature before swapping, but it's now doing about 57 deg C after several hours of light use.
Default 05-21-2009, 01:29 PM
I'd be surprised if the reported CPU temperature had much correlation with the temp of the wireless card. I have the 5300 and it gets warm, but no warmer than the memory or SSD.
Default 05-24-2009, 06:34 PM
Given the passive cooling, it is possible that the one component is heating up the others. Still, you're right -- the main culprit seems to be a misbehaving Flash plugin, driving CPU utilization up.
Did you rig up a third antenna? Otherwise, why the 5300 over the 5100?
Default 05-24-2009, 09:48 PM
Yes, I added the third antenna. To be honest, at the time I bought it I didn't know the 5100 existed. But I'm very happy with my selection.
« Casemod resources? | Mini 9n vs. Mini 9 »
