djermalowicz djermalowicz is offline
Default Using SD Card in USB Reader to Load OS X? - 04-24-2009, 02:15 AM
I am sorry as I am a total newbie, and I have tried searching and must have just missed this, but my question is:
Instead of using a USB flash drive can I use a SDHC card in a USB reader to load OS X onto my (coming) Mini 9?
Thanks for any help and once again sorry I couldn't find it in the search.
Default Re: Using SD Card in USB Reader to Load OS X? - 04-24-2009, 02:44 AM
It should work the same as any other USB storage device.
As for my personal experience, I've had no problems booting from an SD/USB card reader combo to install Linux.
hihrd1 hihrd1 is offline
hihrd1's Avatar
Default Re: Using SD Card in USB Reader to Load OS X? - 04-24-2009, 06:15 PM
im a newbie myself... thats how i loaded osx via the 2 usb method. one was a 8g sdhc, the other a 64mb sd, both kingston. didnt have any issues.... good luck!
« Hard Drive space not adding up? | Which deal did you get on your Dell Mini? »
