CyberPrey CyberPrey is offline
Default Hard Drive space not adding up? - 04-23-2009, 04:30 PM
Hmmm, I am in the process of removing and installing items I want on my new mini.
It came with the 8gb hard drive...
I have 7.11 taken up, and only 600mb free...
Now, when I open the hard drive in my computer, and select all the folders and icons, It tells me there is only 4.5gb used....
somewhere, there is a few more files taking up space, but I have no clue where. I changed the settings to view hidden files, and that didn't change anything..
Anyone have an idea whats happening?
Dell Mini-9 / 16gbSSD / 2gbRAM / BT / Windows 7 RC - Mac OS X 10.5.6
Dell Mini-9 / 8gbSSD / 2gbRAM / BT / Ubuntu Linux - Windows XP Home
saltatory saltatory is offline
Default Re: Hard Drive space not adding up? - 04-23-2009, 05:54 PM
are you using XP?
if so, check out this thread:
some-storage-questions-t7111.html-st=0&sk=t&sd=a
Default Re: Hard Drive space not adding up? - 04-23-2009, 07:36 PM
Yes, the XPHome SP3 that came on it.
I plan on going to windows 7 when I get my runcore 32gb SSD though, but thats going to be a bit
Default Re: Hard Drive space not adding up? - 04-23-2009, 07:45 PM
well, the usual culprits in windows are the page file and hibernation.
Default Re: Hard Drive space not adding up? - 04-23-2009, 11:21 PM
I have hibernation off, and pagefile turned off also.
Default Re: Hard Drive space not adding up? - 04-24-2009, 01:26 AM
system restore?
Default Re: Hard Drive space not adding up? - 04-24-2009, 12:04 PM
thats off to..
Kinda strange... I'm tempted to just do a fresh install from the CD's.
Default Re: Hard Drive space not adding up? - 04-24-2009, 01:37 PM
i'm not sure, but there may be a weird dell-installed partition which is hogging the extra room. try using a disk utility to peek around for a hidden partition. if none is found, i'd just wipe it and start afresh.
Default Re: Hard Drive space not adding up? - 04-24-2009, 03:28 PM
I checked, and only 2 partitions on the drive. The little dell system partition, and the main Windows one.
I did notice that even though I have the swap file turned off, the system SAYS it is using a 2011mb swap file....
Is there a different place to change the settings on that other than in:
My Computer Properties -> Advanced -> Performance Settings -> Advanced -> virtual Memory??
Default Re: Hard Drive space not adding up? - 04-24-2009, 03:33 PM
that's the only place that i know of. try setting a custom page file of 0 mb? (make sure you click "set", not just "ok")
« Additional storage - fastest options | Using SD Card in USB Reader to Load OS X? »
