dizzy dizzy is offline
Default installing XP pro on my mini 9 Problems - 04-17-2009, 12:31 AM
I have purchased a new mini 9 with the stock 4gb with Ubuntu. I purchased the 32 gb RUNCORE ssd and when I try to install the XP Pro OS i get a 000000007B error after loading files. I am using an IOMEGA external DVD to load my XP pro disc( it is an older version,but has a real key and everything is legit.) Can someone help me with this installation of XP Pro on my 32 GB runcore SSD.
Many thanks in advance.
anguish anguish is offline
anguish's Avatar
Default Re: installing XP pro on my mini 9 Problems - 04-17-2009, 11:45 AM
That's a fairly general error. If possible, you may want to try installing from a USB key. I have read of issues with some USB optical drives, and that could be the case. I personally haven't tried installing from a USB optical drive and have only done installs from USB keys (XP Home, XP Pro and Windows 7 so far).
HTH some.
« Just received my Dell Mini 9 | OSX Battery Update Question »
