johnnycrossbone johnnycrossbone is offline
Default Help me decide which system to keep! (for OSX install) - 04-11-2009, 01:06 AM
I accidentally bought 2 Mini 9's, so I need to decide between the following units:
1) Cherry Red with a 16GB SSD/1GB RAM ($240.16 shipped)
2) Onyx Black with a 8GB SSD/512MB RAM ($202.94 shipped)
I plan on upgrading to 2GB of RAM for either system (it's cheap and easy, so why not?), but I guess what I'm trying to figure out is if I should go with the black unit and get the 32GB SuperTalent SSD, or if the 16GB unit will be big enough.
I definitely want OSX, and I proooobably want to have either Adobe Photoshop (500MB) or Adobe Illustrator (733MB) on there.
What's the reliability on these SuperTalent drives like?
Am I gonna be disappointed with 16GB?
What would you do if you were me?
Black Mini 9, 32GB SuperTalent SSD, 2GB of RAM, OSX 10.5.6
LGSilva LGSilva is offline
LGSilva's Avatar
Default Re: Help me decide which system to keep! (for OSX install) - 04-11-2009, 01:08 AM
16gb will not be enough for you, so if you're upgrading memory and ssd the best way is to keep the cheap one 8-)
Default Re: Help me decide which system to keep! (for OSX install) - 04-11-2009, 01:26 AM
Thanks for the advice.
How big was the OSX install on your machine?
I'm a graphic designer and photographer who uses OSX at home and at work, and I'd like to use my Mini 9 for noodling around when I'm on the road.
STiMULi STiMULi is offline
Default Re: Help me decide which system to keep! (for OSX install) - 04-11-2009, 03:20 AM
Something else to think about...
The black one will drive you crazy with smudges or scratches. I have not seen the red one but I would bet that it would be less prone to showing them.
Mini 9 MacBook Aspen White
Runcore 64GB | 2GB RAM | ATP 16GB C6 SDHC | 1.3 Webcam | Bluetooth | OSX 10.5.6 | Fusion w/Windows XP | CrossOver | DellEFI 1.2A5 | BIOS A04 | 77Whr Battery
Will install OSX for Food
« Mac OS | Shopping for Mini 9 »
