newman73 newman73 is offline
Default Cloning an SSD ?? to a second Mini with same configuration? - 04-08-2009, 04:41 PM
Hi All... I am new to the Dell mini community and have a question. I am expecting to recieve shortly my Dell mini 9 with OS X pre installed - 2meg mem, 32 GB SSD, web cam etc.. (Ebay). I am a casual Mac user, ( I use an iMac at work) and would like to know how I can clone a copy of this netbooks HD while its still pristine, on to a 2nd Dell mini 9 running ubuntu with the same configuration.(2 megs memory, 32 SSD) Is it possible by using Super Duper? I saw some of the tutorials using the 2 USB thumbdrives.. but would like to know if cloning would be quicker/easier?
Is there a way to clone the image to a DVD and install from an external DVD? looking for some advice..
Thanks in advance!
newman73
bmcclure937's Avatar
Default Re: Cloning an SSD ?? to a second Mini with same configuration? - 04-08-2009, 05:16 PM
I would check the OSX section of the forums.
You can clone the SSD using SuperDuper of CarbonCopyCloner (CCC)... this will create an exact bootable image.
Procedures for doing this are outlined in the OSX forum
LGSilva LGSilva is offline
LGSilva's Avatar
Default Re: Cloning an SSD ?? to a second Mini with same configuration? - 04-08-2009, 11:12 PM
You could use http://clonezilla.org/ to boot from a usb drive and clone the whole ssd to another usb drive or a sdhc card and then restore it on the other mini.
Maybe super duper can do the cloning but I don't think you'll be able to restore it unless you already have os x installed on the other mini but then why would you need to clone it right?
Default Re: Cloning an SSD ?? to a second Mini with same configuration? - 04-09-2009, 12:32 AM
I see your point....I may need the mac OS on the drive to get the Super Duper restore to work..
as I said earlier, I'm new to the whole Dell Mini 9 community.
would I necessarily need to clone the SSD to a USB drive by using clonezilla?
could I use a portable USB HD that I have lying around? and if so what preparation whould I need to do to that hard drive if any, to make it work?
sorry to be such a noob...
Newman73
LGSilva's Avatar
Default Re: Cloning an SSD ?? to a second Mini with same configuration? - 04-09-2009, 01:24 AM
I think it would be easier to use a small usb drive just to boot clonezilla and to store the image you can use your external hd.
If that's not an option you need to make your external hd bootable: http://clonezilla.org/clonezilla-live/liveusb.php
« Buying your mini 9 from tescos? | How can i tell if i have wireless »
