yaqui316 yaqui316 is offline
Default old iPod as hard drive - 04-01-2009, 02:38 AM
i have an old 40gb iPod laying around and was thinking of using it as an external hd. anyone out there using it? can i atually use it to store my mp3's without itunes overwriting it when it synchs? total noob.
LGSilva LGSilva is offline
LGSilva's Avatar
Default Re: old iPod as hard drive - 04-01-2009, 03:59 AM
You will need to set your ipod to diskmode in itunes and you will need to eject it every time before unplugging it from your computer.
If you want to use it just to store your files you can create a folder and put your files there, itunes will not mess it up.
I know there is a small java application that lets you manage your music from the ipod itself...
« How do I remove the XP and Intel Inside stickers? | Install Webcam Myself? »
