gabat gabat is offline
Default beginner question - 03-28-2009, 08:01 PM
I got MINI 9 with Linux system,few question
1) hOW YOU KNOW CAPSLOCK IS OWN?
i HAVE NOT FIGURED OUT HOW TO OPEN DOWNLOADED FILE.IT IS STORED ON DESKTOP AND CLICKING ON MESSAGE COMES" THERE IS NO APPLICATION INSTALLED FOR THIS FILE TYPE"
3)WIRELESS WORKING AT HOME,DOES NOT WORK IN PUBLIC PLACE-LIBRARY
I WILL APPERCIATE ANY HELP.
THANKS
gabat
ade099 ade099 is offline
Default Re: beginner question - 03-29-2009, 12:21 AM
1. unfortunately, there is no light for the caps lock so you may need to just start typing in your browser window or something.
2. what kind of file are you trying to open? you'll need to download and install an executable unpacker (winzip, winrar, winace, etc) to decompress those file (although i think vista and win7 both have their own unzipping utility built in).
3. you'll need to find out what your library's SSID is and hop on. the librarian should be able to help you with that.
--edit--
and from the looks of it, your capslock was on when you were typing your message
MoInSTL MoInSTL is offline
MoInSTL's Avatar
Default Re: beginner question - 03-29-2009, 08:36 PM
« SD card | Programs quitting unexpectedly »
