iowagn iowagn is offline
Default I installed a 2gb memory upgrade so how - 03-21-2009, 12:03 AM
do I check to make sure the Mini and the os (unbuntu) see it? I don't really want to continue making changes until I know the memory is good.
Thanks!
Default Re: I installed a 2gb memory upgrade so how - 03-21-2009, 12:39 AM
If you press 2 during the initial boot screen (Dell logo), you can go into the BIOS and see the memory size there. I'm sure Ubuntu has a way to display it but I don't know what that would be.
Arapahoe Rappaport Arapahoe Rappaport is offline
Default Re: I installed a 2gb memory upgrade so how - 03-21-2009, 12:47 AM
marcmagus marcmagus is offline
Default Re: I installed a 2gb memory upgrade so how - 03-21-2009, 01:00 AM
Go to a terminal and run "cat /proc/meminfo", will tell you how much memory Linux thinks you have.
Black Mini 9 | 4GB SSD | [s:1kutak77]512MB RAM[/s:1kutak77] | [s:1kutak77]Ubuntu[/s:1kutak77]
RAM: Kingston HyperX 2GB 533MHz DDR2 CL3-3-3-8
OS: Gentoo Linux, ion3 WM
« can we have an "off topic" root thread? | Cannot decide between the Mini 9 vs. the Mini 12 »
