startvlr startvlr is offline
Default Core Temps!!!! - 03-14-2009, 08:02 PM
Hi everyone..I am rewriting this post since I haven't received much feedback from the "hardware issues" section.. I just received my mini 9 and I downloaded coretemp. The unit to me, seems to run a little warm..maybe borderline hot. When running Kaspersky and Skype at the same time, the core temp runs at about 65-70. Is this normal operating temp? I was doing a windows update and the core temp was spiking up to 75-80.. Wouldn't stay there, just spike for around a second or two and then go back to 65-70. Please, someone who has a deep insight on this subject, please reply.. I know I can't be the only one wondering this. Thanks....
Default Re: Core Temps!!!! - 03-14-2009, 08:19 PM
There's quite a bit discussion of temps in the forum. 65-70 is normal for the Mini9 and its passive cooling system. I have seen peaks around 75 but not higher, some people do see higher temps, but I would not worry unless it consistently stayed above 80.
Default Re: Core Temps!!!! - 03-14-2009, 08:23 PM
thanks steve..appreciate it..There are a lot of posts, but none with any clarity...some people are running speedfan..coretemp.. but, again..thank you..
Default Re: Core Temps!!!! - 03-14-2009, 08:26 PM
The consensus seems to be that CoreTemp more accurately reports the temp for the Mini than does SpeedFan.
random4t4x14 random4t4x14 is offline
Default Re: Core Temps!!!! - 04-19-2009, 10:44 AM
Everest Ultimate's newest version (5.0.1) reads the TJunction on the Atom correctly now as well.
Mini 9:
« Mini 9 or Mini 10 ? | Loose screw? »
