ambrozia ambrozia is offline
Default I have a WAN slot? - 03-01-2009, 12:45 AM
My new mini 9 has a WAN slot, also the ATT chip. Got a refurb so didn't configure the WAN. How can I use it?
Retired Mini user
WolfKeeper's Avatar
Default Re: I have a WAN slot? - 03-01-2009, 01:09 AM
Getting an iPad
Default Re: I have a WAN slot? - 03-01-2009, 01:39 AM
Thanks but I understand about 3G, I just don't know how to use the WAN slot for it. Do I buy a card that fits the slot...do I need to add something else inside to use another source than ATT for 3G?
Retired Mini user
WolfKeeper's Avatar
Default Re: I have a WAN slot? - 03-01-2009, 01:49 AM
You say it has the "AT&T" chip, are you sure? Is there a mini-PCIe card in the WWAN slot? (It's the slot below the SSD, lower left corner.)
If you want to go with another provider you would need to procure a different card whose radio is compatible with that provider. AT&T and T-Moble are GSM-based, while Sprint and Verizon user other technology.
Getting an iPad
Default Re: I have a WAN slot? - 03-01-2009, 02:29 AM
it hasn't arrived yet. here is the list
Inspiron Mini 9 (910) Laptop: Intel Atom Processor N270 (1.6GHz/533Mhz FSB/512K cache) No DVD or CD Drive
4 Cell Primary Battery
30W AC Adapter
WAN card Slot
Software
Software
Dell Support 2.0 Software
Processor Label
BOXNET, 1.0
Intel Integrated Graphics Media Accelerator 950
Previously Ordered New
Service Software
Software
Dell Solution Center Software
Operating System DVD
Processor Label
Information
Integrated 1.3M Pixel Webcam
Shipping Material
1 GB DDR2 SDRAM 533MHz (1 DIMMs)
Adobe Acrobat 9.0 Reader
Miscellaneous
Genuine Windows XP Home
Glossy 8.9 inch LED display (1024X600)
Notebook Keyboard
Microsoft Works 9.0
Alpine White
Built-in Bluetooth 2.1 capability
16 GB Solid State Drive
Windows Live
Wireless 802.11g Mini Card
Dell Wireless AT&T built-in cellular mobile broadband (HSPA 7.2)
Default Re: I have a WAN slot? - 03-01-2009, 02:39 PM
Then you don't have to buy the WWAN card - it's already there. You would have to buy service from AT&T if you wanted to use it.
« New member from Norway / is there more Norwegian | Ordered mini 9 stock- will this be fine for my uses? »
