djkrun djkrun is offline
Default Integrated 10/100 LAN (RJ45) - 02-15-2009, 06:50 PM
What is an "Integrated 10/100 LAN (RJ45)" port? I am considering purchasing a Mini 9 and do not have wi-fi at home. Will this port allow me to plug in using the cable from my modem/router? Thanks!
Default Re: Integrated 10/100 LAN (RJ45) - 02-15-2009, 07:00 PM
It's an Ethernet jack. Yes, you can run an Ethernet cable from your router to the Mini - it will work just fine.
Paul Paul is offline
Default Re: Integrated 10/100 LAN (RJ45) - 02-15-2009, 07:01 PM
It means that you can connect the mini 9 to a wired network. The RJ45 is the standard plug/socket for networking. 10/100 is the speed of the network.
But more importantly it means that yes, you can connect it to the router/modem, if you normally connect using a standard network cable.
Default Re: Integrated 10/100 LAN (RJ45) - 02-16-2009, 02:23 PM
Thank you holmes4 and Paul for your prompt, informative responses. Based in part on your information, I ordered a mini yetserday. Your information is much appreciated!
« What kind of memory card | Hello, new here and quick question about external DVD/CD-ROM »
