yoshiki2 yoshiki2 is offline
Default 07-30-2009, 04:09 AM
Can I install windows xp on a memory SDHC? and can i install the programs on the same memory card? can i boot from the memory sdhc?
Default 07-30-2009, 02:07 PM
You cannot boot from the SDHC slot. You can install programs there, though some programs object to being installed on a "removable" drive.
Default 07-30-2009, 04:39 PM
possible to have ubuntu and xp (dual boot) on a 4 gigabytes ssd? or do i need to upgrade it to 16 or 8 gigabytes? ( and where can i get them really cheap?)
  (#14) Old
Default 07-30-2009, 05:54 PM
That seems way too small to me for such a thing. No such thing as a "really cheap" SSD.
  (#15) Old
Default 07-30-2009, 08:22 PM
well what is the regular price for a 16 ssd? or 8 ssd
  (#16) Old
Default 07-30-2009, 08:28 PM
16GB: $63 for one with decent performance, $50 for one that is slow. Newegg (where I am looking) doesn't sell 8GB models.
  (#17) Old
Default 07-30-2009, 11:36 PM
will any ssd with 16 gigabytes work with the mini 9, or do i need a special type?
  (#18) Old
Default 07-30-2009, 11:55 PM
You need a MiniPCIe, PATA, 50mm. If it doesn't specifically say it is compatible with the Mini 9, look elsewhere.
  (#19) Old
Default 08-03-2009, 05:41 PM
Will i note the difference on windows xp (I've read that every card is slow on windows xp), or will I note the difference running 7 or ubuntu. thanks
does the SSD comes with warranty? or am I required to buy the 2 years warranty. ( cannot find the warranty on product details.. thanks)
« Somehow got MacOSX installed on my 10v, question | Howdy »
