Default HELP with the screws - 01-30-2009, 12:11 PM
I just got my mini last night. I was all excited and prepared to upgrade. Had already receiced my Runcore 32gb. I watched all the videos and was prepared to streak through this process. And then, the frigin SSD screws won't come off. Way tight. I got one but the other is now stripped. What to do???
Default Re: HELP with the screws - 01-30-2009, 01:47 PM
Others have reported this problem as well. I wonder if it's due to using the wrong size screwdriver (should be Philips #0). The screws have Loctite to prevent them from loosening but it is the "removable" kind.
A popular solution is to take a Dremel tool with a thin cutting disc and cutting a slot in the screw head, then using a flat-blade screwdriver to remove it. I suggest protecting the area around it to prevent metal shavings from shorting the circuit boards.
cookiemonster's Avatar
Default Re: HELP with the screws - 01-30-2009, 01:49 PM
Here's the other thread where people have discussed this.
Default Re: HELP with the screws - 01-30-2009, 04:54 PM
I wound up chopping off the screw head. With the post remaining. I thing the one screw should be sufficient to hold the card in. What a bummer. Something that I thought was going to be so easy wasn't. I guess it's Murphy's law.
Default Re: HELP with the screws - 01-31-2009, 10:33 PM
I ordered the screws from dell,
the part number is
4270E Screw,M2X3,K Screw Head, Machine Screw,Black Oxide $1.99
My Dell Mini 9 ~$380 : Color Stickers 1 in Green | 32GB Runcore | 2GB RAM | Bluetooth |
US Intl Keyboard| 8GB SDHC | Windows 7 7068 & Mac OS X 10.5.6 | Real HD Light |
Internal Logitech MX Receiver |Belkin Mini9 Messenger bag | Psyopper sleeve !
The Architect's Avatar
Send a message via AIM to The Architect
Default Re: HELP with the screws - 02-03-2009, 11:37 PM
To get the stripped screw out of mine (it came from the factory that way, I sear), I used a Craftsman screw-out. T
he smallest one put into the handle for a mult-bit screwdriver like the one below, worked perfectly. Just be very, very, careful.
HTH
Black Mini9, 1.3MP WebCam, 64GB RunCore SSD, OS X 10.5.6 via Type11 7.7
Now With not one... but TWO gigs of ram!
BT Coming Soon
Aluminum iMac 2GHz, 2gig, 10.5.6
Default Re: HELP with the screws - 02-04-2009, 02:13 AM
Only Philips #0 screwdriver is needed to open the Dell mini 9.
Craftsman Philips #0 screwdriver is the good tool.
« Mini 9/12 noe or wait for ASUS Touch Tablet | Got my refurbished mini 9 today »
