Paul Paul is offline
Default Re: Lost battery monitor - 02-11-2009, 12:54 PM
Well I think I have solved the mystery. My mini already had the correct battery meter installed on it. So when I tried to install it again, by downloading the .exe file and running it, the InstallShield process decided that I must want to remove it which it did. If I then ran the downloaded file again I got my battery monitor back again! I should have left well alone in the first place. Thanks for the advice guys. It shows that operator error can always beat technical know-how.
cookiemonster's Avatar
Default Re: Lost battery monitor - 02-11-2009, 01:15 PM
Well, I'm impressed you had the balls to admit it.
Default Re: Lost battery monitor - 02-11-2009, 04:03 PM
Well, I might just help someone else by 'fessing up
« Noob with HD questions | Can't connect to te internt, just got my dell mini9 Ubuntu »
