John John is offline
Default Need help with cloning - 01-28-2009, 01:57 PM
MY mini is on its way,xp, 8gig, bluetooth, 1gig. Ive been all over the forum and know have more questions then ever.
Cloning is the big one. I thank more people like acronis. So my question is about crapwawe and compression.
Is it better to remove the crapware and decompes before or after I clone :?:
Thank You Everybody
Heed Heed is offline
Heed's Avatar
Default Re: Need help with cloning - 01-28-2009, 03:51 PM
I'd do it before you clone. Set the system up exactly as you like it, use it for a few days to confirm that everything is stable and to your liking then make a drive image.
Everything's Blue, Everything's Blue In This World, All Fuzzy, Spilling Out Of My Head.
zeroprime zeroprime is offline
Default Re: Need help with cloning - 01-28-2009, 09:21 PM
You could always make an initial clone, then rip out the crapware and install the programs you want, use it for a few days to make sure all is well, and make a new clone image if you don't run into any problems.
« Runcore SSD DoA? | Installing Xp »
