0007 0007 is offline
Default DELL mini inspirion 910 upgrade SSD - 05-28-2014, 08:13 AM
have a dell and need to upgrade to SSD has 8 gb of STEC to 128 gb.
Can I use this Toshiba 62GB mSATA SSD SATA II 3Gb / s disk (THNSNB062GMCJ) mini solid state drive
What SSD advise me?
lswartz lswartz is offline
Default 05-28-2014, 10:28 AM
The Mini 9 only uses a mini-PATA 50mm PCI-e Solid State Drive. This is a unique drive for the Mini 9 & there aren't many of them left. Do a search for Mini 9 SSD's. I found a few on Google Shopping, sort of $$ though. Try eBay & Amazon as well, you might have some luck.
If it does not say that it will fit the Mini 9 or Vostro 90 then it probably will not work.
Default 05-28-2014, 02:00 PM
the limit is 64 gb with the appointment and try to put more gb SSD!
my difficulty is putting the SSD with the same input slot and size (equal to the naked eye) but he recognizes other brand!
problems will not!!
Default 05-29-2014, 10:56 PM
Right - you can find SSDs that fit in the slot but that don't work in the Mini 9. These are usually SATA SSDs. lswartz is absolutely correct - if it doesn't say it's for the Mini 9, it won't work.
Two choices available now are RunCore 64GB Pro IV Light 50MM PCI-e SSD for Dell Mini 9 Vostro A90 | My Digital Discount and http://www.amazon.com/Kingspec-64GB-.../dp/B008KWD0Z2
The RunCore is the better quality SSD, the Kingspec is much cheaper. Kingspec has a 128GB model also available through Amazon.
« Ideas? | New and helpless! »
