loxx loxx is offline
Question Intel Solid-State Drive 310 Series - 01-13-2014, 06:43 AM
Hi Friend,
I want to know, can i use Intel Solid-State Drive 310 Series to my dell mini 9.
I already try put it to slot ssd but it won't work .. when i switch ON , it go light a second .. if i remove it , put it at USB it works.. thanks
lswartz lswartz is offline
Default 01-13-2014, 12:05 PM
The Mini 9 only uses a mini-PATA 50mm PCI-e Solid State Drive. This is a unique drive for the Mini 9 & there aren't many of them left.
If it does not say that it will fit the Mini 9 or Vostro 90 then it probably will not work.
Default 01-13-2014, 03:22 PM
Thank's Sir, i'm guess need to mod the usb slot ,if i want to use it.
Default 01-18-2014, 02:18 PM
You can't use that drive in the Mini 9. If you have a USB-SATA adapter it can be connected by USB but you'll lose all the benefits of an SSD by accessing it over USB2.
Default 01-19-2014, 02:14 PM
noted with thank's sir..
intel
« new member-need OS help | Hey all, first timer here with a couple issues. »
