Worsleyman Worsleyman is offline
Default Samsung n150 plus problems - 07-05-2013, 09:48 PM
Hi all new here I've a couple of problems really and would be grateful if anyone could help me!! What startup programs do I turn off because its affecting my ram i do not know which ones to turn off!! Q2 I've tried a thousand times to do my updates for windows service pack 1 I've tried to update but it say failure to configure reverting back blah blah blah I've turn my anti virus off and I've even used fix ya and it still won't update please can anyone help????
Default 07-07-2013, 03:16 PM
This forum specializes in the Dell line of netbooks - we don't tend to have expertise on other brands. But it sounds as if you have more general Windows problems. Try Home - Microsoft Community
desone01 desone01 is offline
desone01's Avatar
Send a message via Skype™ to desone01
Default 04-19-2014, 02:58 AM
I have had the same problem with my Mini 1018. It won't update the Service Pack 1. I have resorted to a fresh install. I am taking the opportunity to install Win 7 64 bit.
Dell Mini 1010 160GB hard drive
Dell Mini 1012 250GB hard drive 2GB RAM
Dell Mini 1018 1,000GB hard drive 2GB RAM
Dell XPS M1730 X9000 CPU NV M9800GTX 2GB video. 8 GB ram 256GB SSD & Seag hyb 750GB
Dell XPS M1730 X9000 CPU NV M9800 GTX 2GB video 4gb ram 256gb SSD & 200gb Hit hd
Dell XPS M1330 2.6ghz Seagate 750gb hd.
Dell XPS M1330 2.5ghz Western Dig 750GB hd.
Dell Studio XPS 1645 I7 840QM CPU 8GB Ram.
lswartz lswartz is offline
Default 04-19-2014, 05:07 PM
Intel Atom processor is only 32 bit. You might try a fresh install of the 32 bit OS as it should update without a problem.
desone01's Avatar
Default 04-22-2014, 01:45 AM
The Dell Mini 1018 can run the 64 bit operating system. I think the 1012 can run 64 bit as well. The Atom CPUs N450 (1012) and N455 (1018) appear to be ok for 64 bit. The Mini 9 and 1010 can't.
I solved the problem with the updates. I installed Service Pack 1 manually and then used the Windows Update to install the other updates.
Again they wouldn't install. I searched the Microsoft site and found a hotfix KB947821 fixed the update problem.
Default 04-22-2014, 11:31 AM
That is super, & I learned something too.
« My Dell Mini 1010 | Ideas? »
