bobgreen13 bobgreen13 is offline
Default Battery Question - 01-24-2009, 08:23 PM
Yes Yes, there are many battery questions around and I was researching and couldn't find a thread connected my question so here I go.
Basically, when I charge my battery up to 100% should I take it out and then use AC power after that?
I am one of those people who would use my dell mini on the go and take the battery w/o my charger because I know that there isn't a power source everywhere.
:?: thanks for the help
Black Mini 9 - 16 SSD - 2GB Ram - 1.3 Cam - Bluetooth 2.1 - Windows XP
Fallstar Fallstar is offline
Fallstar's Avatar
Default Re: Battery Question - 01-24-2009, 08:33 PM
AFAIK, you can leave the battery in while plugged into AC power. The battery will stop charging once it's full.
Default Re: Battery Question - 01-24-2009, 08:58 PM
Yea I read about that one, I guess I'll just leave it in there, though it seems like a never ending cycle
thanks
Default Re: Battery Question - 01-24-2009, 09:35 PM
Lithium-Ion batteries are designed to be used in this fashion. Don't worry about it.
Default Re: Battery Question - 01-25-2009, 01:22 PM
Thank you holmes4 for the reassurance and thank you fallstar for the help
« Problem installing daemon tools | Best Storage Format? »
