krysh_1140 krysh_1140 is offline
Unhappy Wireless Manager Problem... Pls. Help! - 04-23-2012, 11:06 AM
hi.. i'm a newbie here.. i registered bcoz i have a problem in accessing the message box of my wireless manager..
Wireless Manager Program Version: 5.2.1045.43
OS: Windows XP
Laptop Model: Dell Inspiron Mini 9
After clicking the Message box button, this message appears:
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Invoke or BeginInvoke cannot be called on a control until the window handle has been created.
And for its details....
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: Invoke or BeginInvoke cannot be called on a control until the window handle has been created.
at System.Windows.Forms.Control.MarshaledInvoke(Contr ol caller, Delegate method, Object[] args, Boolean synchronous)
at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
at Semc.MobileComputing.Pcsw.View.MessagesView.AddMes sage(Object reference, Int32 imageIndex, String time, String name, String text)
at Semc.MobileComputing.Pcsw.Presenter.MessagesPresen ter.AddMessage(TextMessage message)
at Semc.MobileComputing.Pcsw.Presenter.MessagesPresen ter.OnMessageEvent(Object sender, MessageEventArgs e)
at Semc.MobileComputing.Pcsw.Presenter.MessageCenter. Notify(MessageFolder list, MessageAction action, TextMessage message)
at Semc.MobileComputing.Pcsw.Presenter.MessageCenter. AddMessage(MessageFolder list, TextMessage message)
at Semc.MobileComputing.Pcsw.Presenter.MessageCenter. MoveFromInbox()
at Semc.MobileComputing.Pcsw.Presenter.MessagesPresen ter.Start()
at Semc.MobileComputing.Pcsw.Presenter.PresenterCore. StartMessagesPresenter()
at Semc.MobileComputing.Pcsw.Presenter.MainPresenter. ClickMenuViewMessages()
at Semc.MobileComputing.Pcsw.View.MainView.ClickButto nMessages(Object sender, MouseEventArgs e)
at System.Windows.Forms.Control.OnMouseClick(MouseEve ntArgs e)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
WirelessManager
Assembly Version: 0.0.0.0
Win32 Version: 0.0.0.0
CodeBase: file:///C:/Program%20Files/Ericsson/Wireless%20Manager/WirelessManager.exe
Card
Assembly Version: 5.2.1045.43
Win32 Version: 5.2.1045.43
CodeBase: file:///C:/Program%20Files/Ericsson/Wireless%20Manager/Card.DLL
Presenter
CodeBase: file:///C:/Program%20Files/Ericsson/Wireless%20Manager/Presenter.DLL
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.3614 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 2.0.50727.3636 (GDR.050727-3600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Device
CodeBase: file:///C:/Program%20Files/Ericsson/Wireless%20Manager/Device.DLL
View
CodeBase: file:///C:/Program%20Files/Ericsson/Wireless%20Manager/View.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
I don't know this things.. can someone pls. help me? i have to access the message box so that i can read my inbox and register for some internet connection promos.. but i can't because of this problem..
Hoping for an immediate response regarding this matter.
Thank you very much.
Bigmatie Bigmatie is offline
Default 04-26-2012, 10:19 PM
I could not get wifi working either
« need help with my dell mini re highlightlight and drag and drop | Hello! »
