Maria Silva Maria Silva is offline
Default Help please! - 02-22-2012, 05:09 PM
If I buy a 16 GB SDHC card can I install the «Office package» there and run it from the card?
I'm asking this because my mini dell as so little memory that it's always asking me to uninstall things to free some space.... (and I already don´t have anything install, not even the Ofiice!)
Can someone help me?
Thanks!
Maria
Dan_Shane Dan_Shane is offline
Dan_Shane's Avatar
Default 02-22-2012, 05:59 PM
Thanks!
Maria
Maria,
Depending on the operating system version you are running this can indeed be done. I previously installed a trimmed-down version of Windows 7 on my Mini 9, then I installed all future programs on the 16-GB SD card. It worked fine, though program loading was naturally a bit slower than it would have been if installed on the system drive.
-- Dan Shane --
Dell Latitude 2100 | Ball Field Green | 2 GB RAM | 500GB 7200 RPM HD | Windows 8.1 Enterprise| Mac OS X 10.6.8 (Snow Leopard)
Dell Inspiron Duo | 2 GB RAM | 320GB 7200 RPM HD | Windows 8.1 Enterprise| Mac OS X 10.6.8 (Snow Leopard)
« Must Have Software for Mini 9 | battery problem »
