e8baller e8baller is offline
Default Problem installing daemon tools - 01-22-2009, 05:19 AM
Hello, Im trying to install d-tools so I can use disc images. After installing, the system installs a scsi controller (ST3MP 28 SCSI Controller). After reboot, the system crashes to the blue screen and I get the message ...an attempt was made to execute non-executable memory... I have to uninstall the controller for windows to work again, but that makes the d-tools program unusable.
I dont have this problem on any of my desktops.
Your help is appreciated. Thanks!
Mini-9 / 8gb SSD / 2gb Crucial RAM / 16gb aData SDHC / Win XP Home
Default Re: Problem installing daemon tools - 01-22-2009, 05:38 AM
Ah I fixed the problem by simply downloading the newest version of d-tools lite. Ive been using and re-installing v329 for so long on my other comps i didnt think it would be a problem on my mini. Thanks for your time!
Circs Circs is offline
Default Re: Problem installing daemon tools - 01-24-2009, 09:42 AM
If you get something like this again disabling the no-execute flag will fix it.
(But potentially leave a security hole open.)
Netbooks -> Mini 9 - 2gb Gskill low latency - Ubuntu 8.04
Asus Eee 701 4g - 1gb - Ubuntu 8.04.1
Desktops -> Phenom Quad @ 2.8 - 16gb - 4x Raptor X in RAID 0 - 2x 4870X2
Brisbane 1.9 @ 2.7 - 4gb - 80gb
Many others, all Linux.
« Charging battery for first time | Battery Question »
