Default Upgrading Flash - 12-27-2011, 05:50 AM
Hey hey,
Just bought a Mini 9 running Ubuntu 8.04 and want to upgrade to the latest version of Adobe Flash. Do I need to move to a later version of the operating system?
Thanks for humoring a newbie.
-A
Default 12-27-2011, 01:58 PM
no, just upgrade, there should be no problems, just make sure its compatible with Ubuntu
Default 12-27-2011, 03:14 PM
If you look in Administrative, System, Package Manager & search for Flash you should find 'flashplugin-installer'. Just click on it & then click on the green check mark which is apply. That will install flash for you.
Dell Mini 9 | Ubuntu 10.04 Netbook LTS | 2 GB RAM | 4 GB SSD | BIOS A04
Default 12-27-2011, 04:49 PM
Got the "install_flash_player_10_linux_tar.gz" through the Package Manager, but still no dice. Adobe says Ubuntu 10 is required...
Considering an OS upgrade. Any reason why I shouldn't take this route?
Default 12-27-2011, 07:50 PM
Are you going to do a clean install? If you chose my release (10.04) you will need to connect via Ethernet to get the Broadcom wireless driver downloaded. I think 10.10 to 11.10 have it included. You can try out any releases before installing & if you like it, then install. It will run off your thumb drive & is a bit slow to boot up. Make sure you have you boot sequence set in BIOS so USB boot is 1st & legacy is enabled.
Download | Ubuntu
Just in case you needed a link.
flash player, mini 9, ubuntu 8.04
« Dell Mini 10v Bricked | F1 Brings black screen to my mini 10v. »
