peterlukecampbell peterlukecampbell is offline
peterlukecampbell's Avatar
Default 1018 wont turn on but power is active? - 06-13-2011, 12:10 PM
After getting windows 7 re-installed I've downloaded drivers, but wondering do you have to unzip each file and run each driver manually? is there an automatic way to install them? Thanks in advance
IGNORE THE TITLE
Cool 06-13-2011, 01:54 PM
each one that you download should be an executable file, just click on each one.....so to answer your question, NO there is no way to do them all at once.....they must be done one at a time....
PS. Welcome to the forum....
« Which OS is best for longest surfing time on battery? | Dell Streak ring tone »
