technomad technomad is offline
Default Runcore SSD DoA? - 01-19-2009, 11:34 AM
Hi,
I'm just waiting delivery of my Dell Mini 9. I've already received the Runcore 64GB SSD from Memoryc, and went to format it via the USB i/f prior to installing OS X. SSD doesn't show up on my Mac desktop, nor does it appear as a device on the USB bus. I'm therefore assuming it's DoA, or am I missing something here?
Richard
jds394 jds394 is offline
Default Re: Runcore SSD DoA? - 01-19-2009, 11:52 AM
I would suggest that you try it in your mini when it arrives, at least to make sure it's the drive and not just the usb connection or host.
I guess it could be a faulty micro usb cable also.
My Mini 9: Black, Windows 8 Beta, 2GB RAM, 32GB Runcore SSD , 32GB SDHC, Mobile Broadband
helius helius is offline
Default Re: Runcore SSD DoA? - 01-19-2009, 05:29 PM
What is the return period? I definitely wouldn't wait until after that.
Default Re: Runcore SSD DoA? - 01-19-2009, 09:54 PM
I'm tempted to wait until the Mini arrives, but really wanted to use the USB connection as the easy way of getting OS X onto the drive before installing it.
I did have an interesting conversation with MemoryC's support: according to RunCore, some SSDs have a default drive letter in Chinese that some Macs can't read, so I should be able to format it on a PC first. Haven't got a PC (or even a Parallels install atm) so haven't been able to try that, although i do suspect it to be BS, as I'd expect the device to still show on the USB bus - that's at a level way below disk firmware/format.
Any other thoughts?
Thanks
Richard
Default Re: Runcore SSD DoA? - 01-20-2009, 12:29 AM
"A default drive letter in Chinese that Macs can't read"? This makes no sense at all.
My recollection is that the RunCore comes unformatted - just a blank drive. It can be formatted any way you want.
Default Re: Runcore SSD DoA? - 01-20-2009, 09:16 AM
My 32GB Runcore came preformatted with a bizarre set of characters as a volume name
Josh
Default Re: Runcore SSD DoA? - 01-21-2009, 07:55 AM
Yeah, it seems that they are bench tested in the factory to assure there will be no DOA drives. Mine had a partition with chinese characters as well. I think it was NTFS..
Dr Some-what Evil's Avatar
Default Re: Runcore SSD DoA? - 01-25-2009, 06:46 PM
Find a friend willing to let you use his/her windows pc to format it. if it is still not being reconized on the windows machine id suggest contacting Runcore ASAP.
Mini-9
STEC 8 gig SSD
RAM 2Gig 800Mhz.
WWAN parts in place
Default Re: Runcore SSD DoA? - 01-25-2009, 07:25 PM
That assumes you have a friend with a Dell Mini.... The RunCore SSD can't be connected to just any PC.
I would go into the BIOS setup and make sure it is recognized.
Default Re: Runcore SSD DoA? - 01-25-2009, 08:11 PM
I would go into the BIOS setup and make sure it is recognized.[/quote]
I didnt say it but I was referring to using the USB cable to check it. Thanks though.
Mini-9
STEC 8 gig SSD
RAM 2Gig 800Mhz.
WWAN parts in place
« U PEOPLE FREAK MY OUT | Need help with cloning »
