tooaud2 tooaud2 is offline
Default Bios - 03-30-2011, 07:09 PM
Okay I got into the wherever #2 is supposed to take me but I have no idea how to tell what size internal disk is??
I am a very very newbie here so what is a flash drive? one that you stick into the side of the computer?? or do I still need the external dvd hard drive?
Thanks for your patience!
Cool 03-30-2011, 09:34 PM
yes the flash drive sometimes also called a thumb drive can be used or you can use the external CD/DVD drive..either should work
« Problem HELP again | Help needed, should i buy this? »
