dew2 dew2 is offline
Default Problem HELP again - 02-06-2011, 03:37 AM
Awhile back I posted. I got a rebuilt computer and tried to install Win XP Pro off the disc that came with it, on to my Mini9.I learned it was not legal.So I bought a new Win XP Pro disc.
I try to install it,it gets to "starting windows" phase of installing, then I get a error message it says,
stop c0000221 unknown hard error\systemRoot\system32\ ntdll.dll
How can I install my new WinXP Pro?? Is there a way around this error??
Default 02-06-2011, 01:42 PM
A Google search of this error message generally implicates a defective hard disk. You can try doing the install from scratch, deleting any existing partitions, and see if you get further.
Default 02-07-2011, 12:28 AM
I tried again neither disc of WinXPPro one new and one for another computer work and both get the same error.
I did google it before I asked here,I was hoping here I'd get better advice.I did reset to defaults,I dont know what SB V-Link is, but from online checking I was to disable it?
No partitions,set to defaults dont work.I can and did intstall WinXPHome.
Its disturbing I can't use pro.
Each time I install after going to Windows updates, My mini9 at each boot runs diskcheck and shows a unknown error.Is there a chance I can stop the chkdsk? How about if I updated the bios? would that give a better chance of getting Pro working? Thanks once again for the help!
Default 02-07-2011, 03:00 PM
Can you still install XP Home? Is your XP Pro an SP3 version? I think SP3 is needed to add some driver support that the Mini 9 needs to boot.
Default 02-07-2011, 03:14 PM
Yes both discs are WinXPPro SP3 One is a dell the other is original Microsoft.
Default 02-07-2011, 05:23 PM
Does XP Home install ok now?
Default 02-07-2011, 09:52 PM
Yes XPHome installs just fine.I installed after trying each Pro disc at least 3 times.
Default 02-08-2011, 02:08 AM
I'm out of ideas, then.
Default 02-08-2011, 02:33 AM
When I start a clean install is it the BIOS that controls the install? Seeing the SSD is blank.
I just ordered a supertalent 16GB with the mydellmini discount.I might try a upgraded bios?? But I do need your advice, Might it with a different bios help with getting Pro installed?
Where does the down load go before its installed on the SSD?
Default 02-08-2011, 06:13 AM
no the BIOS does not, that is why windows formats the drive first, the install actually DOES go to the hard drive into a temporary directory and also creates a temporary boot file, that is why if you stop/abort the install, it will restart on its own (from the beginning usually)..the BIOS has really nothing to do with the install, it is NOT specific to windows or any other operating system
« mini 10 wont load some internet pages | best os to reinstall on my mini »
