towerworker towerworker is offline
Default Echo audio from speakers - 01-25-2011, 08:43 PM
I have a 2 yr old mini 9 that I bought new and used very little. It has XP and very little else. I intended to post this question a long time ago but work and other issues put the mini at the bottom of the priority list. Now I find I have much spare time so this is my question:
The audio has an intense "echo" quality about it. So much so that normal listening of, for example music is impossible. I can find no way to disable the echo.
What am I missing?
Wayne
Default 01-26-2011, 12:07 AM
Does the "echo" affect audio over the headphone jack?
Default 01-26-2011, 02:27 AM
That's a good question and one I never considered. I will check that and post my findings.
Wayne
« Dell mini 9 screen issue | New member/old problem »
