Tessa Tessa is offline
Default Wireless Driver System Error - 12-26-2010, 10:08 PM
My 910 mini was having trouble running Windows XP because of hard drive space. SO I downloaded Ubuntu and am running it on that from the USB before I commit to it. I clicked on the button to activate the Broadcom STA Wireless driver but got an error message saying SystemError:installArchives()failed.
What does that mean?
Default 12-26-2010, 11:58 PM
I dunno. But this page has info about getting Broadcom WiFi drivers working in Ubuntu. Pay attention to the notes about LiveCD/USB use where you manually load and unload kernel modules/drivers.
Question 12-27-2010, 12:22 AM
Thanks but the page you sent me to is waaaaay over my head. I did manage to get into the command window but got no information when I typed the command lspci l Wireless
Maybe because I'm running Ubuntu from a USB.
Can anyone walk a nearly illiterate new Ubuntu 10.10 for netbook user through installing a wireless driver so I can get this working? Otherwise it's back to Windows XP......
Default 12-27-2010, 03:09 AM
The easiest way may be: connect to the network via a wire, then open a terminal and run:
Code:
sudo apt-get update &&
sudo apt-get install bcmwl-kernel-source &&
sudo modprobe -r b43 ssb wl &&
sudo modprobe wl
I haven't tried it on a LiveCD/USB but I hope that after those commands, you'll be able to choose a wireless network via the taskbar icon.
For the curious, here's a description of what the commands do (as comments after #). The "&&" between commands means stop if a command fails.
Code:
sudo apt-get update && # get updated software info
sudo apt-get install bcmwl-kernel-source && # install driver
sudo modprobe -r b43 ssb wl && # unload conflicting drivers
sudo modprobe wl # load driver
lauriem04 lauriem04 is offline
lauriem04's Avatar
Default 12-28-2010, 03:38 PM
There's a great post on how to fix this error here:
Ubuntu on the Dell Mini: Broadcom Wireless Driver Fix In Maverick
BTW, ubuntumini.com will be a great resource for you if you decide to commit to Ubuntu. Before you do so, though, I would suggest checking out a couple of other Linux distros. My personal favorite is Linux Mint: Main Page - Linux Mint.
Mini 9 (910): Cherry Red, N270, 2 GB RAM, 16 GB STEC SSD, XP Home
Mini 10v (1011): Passion Purple, N270, 1 GB RAM, 160 GB HDD, XP Home
Inspiron 11z (1110): Passion Purple, SU4100, 2 GB RAM, 250 GB HDD, Win7
Alienware M11x R1: Cosmic Black, SU7300, 4 GB RAM, 160 GB HDD, Win7
Latitude 2110: Blue Ribbon, N470, 2 GB RAM, 250 GB HDD, Touchscreen, Win7
Zino HD (400): True Blue, Athlon X2 3250e, 4 GB RAM, 500 GB HDD, Win7
Plus a few others not discussed here...
« C: drive is too full to remove programs | Wireless connection problem »
