drogosel drogosel is offline
Default Base System Device problem - 01-14-2009, 02:12 PM
Hello,
Can someone help me with this driver or were i can find it, what it is ?
Thank you very much !
somms somms is offline
somms's Avatar
Default Re: Base System Device problem - 01-14-2009, 02:16 PM
Originally Posted by drogosel
Hello,
http://support.dell.com/support/downloa ... eid=264714
Default Re: Base System Device problem - 01-14-2009, 02:42 PM
Didn't work ? I installed battery meter but it is the same problem.
Retired Mini user
WolfKeeper's Avatar
Default Re: Base System Device problem - 01-14-2009, 02:50 PM
I thought that was the SD card controller (Windows finds the SD part just fine on it's own, but not the MMC or MS ones.)
Getting an iPad
Default Re: Base System Device problem - 01-14-2009, 02:55 PM
and what should I do ? any help ? please
Retired Mini user
WolfKeeper's Avatar
Default Re: Base System Device problem - 01-14-2009, 04:39 PM
Did you install this driver?
Getting an iPad
jdizzle jdizzle is offline
Default Re: Base System Device problem - 01-14-2009, 06:37 PM
try the synaptics touch pad driver
Studio 1458 | Fingerprint magnet black Windows 7
Diztop D945GCLF2 | dual-core Intel® Atom™ processor 330
geox geox is offline
Default 01-16-2011, 02:32 AM
« trash can | Please Can Anyone Help ?? ( Plus A Welcome Post ) »
