dew2 dew2 is offline
Default Is there a fix - 10-26-2010, 12:19 AM
I discovered my scroll right doesn't work.The key at the bottom right of the key pad that also has End in blue on it. Is there a fix, or is something broke?
Also if I may ask I have CA protection,is there something better for free,that may use less space ? Thanks ahead of time!
Default 10-26-2010, 12:36 AM
For a free antivirus solution, try Microsoft Security Essentials.
As for your key, does it not work in any application?
UNCNDL1 UNCNDL1 is offline
UNCNDL1's Avatar
Default Microsoft Security Essentials - 10-26-2010, 12:56 AM
Yes, there is a free download for this virus program on Microsoft Site. It works seemlessly in the back ground with the windows os programs. They recently discontinued support for the Windows Live virus program that i had used for 3 years. The essentials is their new addition to the windows community.
Mini 10v/1GB RAM/160GB HD/ BIOS A06/SL 10.6.6
Mini 9 /2GB RAM/ 16GB SSD/BIOS A05/SL 10.6.6
OSX Installation via USB & Mac
NBMaker 0.8.4.RC1 / NBI 20100616212351
"Remember to back up your hard earned work with a boot-able disc BEFORE upgrading!"
http://osx.mechdrew.com/guides
http://dl.dropbox.com/u/863180/Netbo...212351.app.zip
Default 10-26-2010, 01:54 AM
No it does not do any thing.I found it be accessing the BIOS and changing the boot to CD. I then tried it for right scroll and its a no go.
I also have my BIOS password protected I dont know how I did it but it is! Can I set it to no password required?? If so how? Thanks holmes4
Default 10-26-2010, 01:35 PM
If your BIOS became password-protected, you can try calling Dell support and asking for the unlock code based on your system tag. I know they'll do this if you are under warranty. If not, I have seen on eBay services that will do this for you for a fee.
Default 10-29-2010, 02:14 AM
Back to the scroll right key;;Is there a fix?? What can I do
Thanks for the protection suggestions I now have security essentials.
Default 10-29-2010, 07:54 PM
The only thing I can think of is to reset the keyboard map, but that's a long shot. Which model Mini do you have?
Default 10-30-2010, 01:14 AM
The 910 or mini9
Default 10-30-2010, 12:54 PM
Setting keyboard matrix
1. Turn off your computer
2. If your computer is connected to the ac adapter, disconnect the ac adapter from the computer
3. Press and hold the following key combination for the desired keyboard matrix :
_ United States : <Fn><S>
_ United Kingdom or US-International : <Fn><K>
_ Japan : <Fn><J>
_ Korea : <Fn><E>
4. Connect the ac adapter to the computer then plug it into a wall outlet or surge protector
5. Release the key combination
Default 10-31-2010, 03:57 PM
So I powered off,Held Fn and S key down,powered on while holding keys down, then released keys after powered up.
Still nothing Guess its more than that.New key board??
I can get by the way it is but it leads me to believe more keys may stop working. Thanks holmes4!
« Hi Community! | crackling sound on startup/shutdown »
