dew2 dew2 is offline
Default 32GB Runcore Help - 09-27-2010, 03:09 PM
I have a 32GB runcore lite,Also a 16GB Ridata SDHC both new.
I want to do a new install of Win XP SP3. What I need to know is what do I install on the SDHC to keep the runcore at its optimum speed,Can I install my CA internet security on the SDHC? CC Cleaner?Google earth?
Maybe what I should be asking is what is the least I can install on the runcore?
Are there any other suggestions to help me?? Thank You!!!
I plan on the SDHC as a permanent fixture.
Default 09-27-2010, 05:30 PM
You will find that most applications will not install to a removable drive. I don't recommend doing this for programs that are frequently accessed, such as security programs. You can move your Documents folder to the SD card. If you also have 2GB RAM you can disable the pagefile and, if you want, disable hibernation and remove the hibernation file to gain some more space.
« operating system not found | Can you tell me what model Mini this is? »
