Default Is this normal? (Battery issue) - 08-28-2010, 12:03 AM
I searched but couldnt seem to get an answer. Just purchased a dell mini 10 (1011) that was used 4 times. Computer off the led is white but when i boot either xp or ubuntu the light will eventually go amber/white and the screen will dim everytime it cycles battery power to ac power. i unplug and its fine for a few mine. i got a replacement battery from dell but its doing the same exact thing.
Default 08-28-2010, 12:32 AM
It's not normal.
Default 09-13-2010, 04:43 PM
update:
dell replaced motherboard and its still doing the same problem. no charge while in use; white/red led
Default 09-13-2010, 06:34 PM
Did Dell test it with your battery and charger? Only thing left is the charger.
Default 09-14-2010, 03:05 AM
i had them send me a new battery so its not that, i sent the charger with it when they replaced the motherboard so i guess i can try to get them to send me another then im out of ideas
« Dell Warranty Ship Parts? | Will the Mini 10 do.... »
