| Guru Posts: 1,993 Join Date: Apr 2009 | When wired, open a terminal and try: Code: sudo modprobe -r wl && sudo apt-get purge bcmwl-kernel-source && sudo apt-get install bcmwl-kernel-source && sudo modprobe -r b43 ssb && sudo modprobe wl If that doesn't work, I'd try a LiveCD/USB (Instructions on enabling the Broadcom driver on a LiveCD/USB, make sure you note the LiveCD/USB section). You might also be able to swap the Mini's Wifi card into your other laptop to test. But that's a bit more effort, and I don't know if your other laptop will accept the Mini's card (many laptops will, but many won't). Mini 1012 | SSD | Intel 6200 Wifi | Ubuntu 11.10 64bit |
(#4)
(#5)
| Junior Member Posts: 1 Join Date: Jul 2009 | What about a software update? |
« Hello, world.
Mini 9 is full! »
