Default Latitude 2100 keyboard cable connector - 08-18-2010, 11:43 PM
I think I may have broken the white part of the cable connector for my Latitude 2100 keyboard cable, is it supposed to swivel? It has come off and I can't fit the cable back in it. The black bit on the motherboard looks fine. How do I get a replacement, how does the cable go back. Help!!!
I had taken the machine apart to fit an SSD.
Default Dell support - 08-20-2010, 01:44 PM
Dell "support" have only one solution, a new motherboard, aargh!!!!
Default Happy Ending - 08-26-2010, 04:09 PM
I was advised by the suppliers of my machine to contact the UK warranty centre (it has a three year on-site warranty). They, fortunately, took a different view to the US on-line "support" and sent out an engineer with a new keyboard and a refurbished motherboard. As it turned out the clip was not broken just dislodged, he solved the whole problem in less than 10 minutes and used no parts. I am very impressed by the UK Dell service!
I feel a bit stupid and cack handed but all's well that ends well. I was very pleased that the Dell warranty call centre decided that as I was following Dell instructions to change a user replaceable part (the disk) the problem I caused was covered by the warranty. Much better than the offer of a $354 replacement motherboard from the US operation.
The SSD is a great improvement. Silent machine and a fair bit nippier!
2100, cable, connector, keyboard
« ram upgrade. . . | Using Print Screen button »
