desgnr desgnr is offline
Default Battery & File questions. - 01-08-2009, 03:22 PM
Is it ok to keep charging the battery every 4 hours or should i use AC power ?
I see some people say to Uncompress the files on the C drive.
Why does the Mini come with the compress files option checked ?
norrisg norrisg is offline
Default Re: Battery & File questions. - 01-08-2009, 05:53 PM
A battery has a more-or-less fixed number of charge/discharge cycles it can provide. If you are able to use AC, then you should probably use it.
The Mini comes comes with a compressed drive to make more space available for what you put on it.
Black Mini 9 2GB/64GB - XP
White Mini 9 2GB/4GB - UNR 9.10
« Install software from USB flash drive | Mini 9 Battery Conditioning? »
