Default will a dell mini10 or 1011 lid/top section fit a mini 10v? - 07-21-2010, 08:46 AM
hi there, would a dell mini 10 or 1011 lid or top section fit a dell mini 10v i was going to change the full screen etc if this was possible?
also does a mini 10 or 1011 battery fit a mini 10v
kind regards
jim
fdalbor's Avatar
Smile 07-21-2010, 12:36 PM
kind regards
jim
There are differences in the two top sections and they will not interchange. This has been tried before without much success. I have heard it is possible to take the screen itself and mount it in the other lid; but the leads are very small and easily broken.
The battery will fit; but it has to be shaved a bit to fit in the 10v. the 1011 and 10v are the same unit. Hope this helps a little. fdalbor
Compaq R4000 laptop AMD 64
Compaq SR2034NX AMD 64
lauriem04's Avatar
Default 07-21-2010, 02:35 PM
If what you are hoping to do is swap the screen on a Mini 10v (1011) with the HD screen from a Mini 10 (1010), it has been tried before without success. See this thread for more details:
http://www.mydellmini.com/forum/dell...ort-no-go.html
There is some discussion of shaving the 1010 battery to fit a 1011 in this thread:
http://www.mydellmini.com/forum/dell...l-battery.html
« Web Cam Issue | Mb a dumb question But here goes... »
