LAK LAK is offline
Default used 1010 and system restore - 05-14-2010, 02:09 PM
Hi, I bought a used 1010 and its messed up and I cant do anything with it. I tried to do a system restore with ctrl f11 but it didnt work.
I have all of the disks, is there a way to restore the system to the original one using the disks.
Than you,
L
Default 05-14-2010, 02:40 PM
If you have a USB CD reader, you should be able to reinstall the OS from the Dell restore CD by booting from CD.
« Xbox 360 on Dell Mini 10v? | Mini 10 GPS install »
