Buffy Buffy is offline
Default Side way screen - 04-10-2010, 10:53 PM
Some how while cleaning the keyboard I hit a combination of keys the changed the screen....
The screen is turned 90 degrees to the left... How do I get it back straight...
Thanks
Gary
I found the answer.....
Ctrl Alt up arrow....
Default 04-10-2010, 11:12 PM
Welcome to the forums.
You discovered the default Intel screen rotation shortcuts. Ctrl+Alt+Arrow Key.They're great fun on display models in stores
mehboob mehboob is offline
Default 04-12-2010, 03:09 PM
That mode is mainly used if you want to use your netbook as a ebook.
# Netbookfiles.com Your Netbook's Software and Driver Source!
CLSmith CLSmith is offline
Default 04-17-2010, 06:38 PM
Great info. Now on ebooks. Do I need to start anew post somewhere else? I want to know how to put ebooks on my mini9. Do I need software?
Cool 04-17-2010, 06:43 PM
probably not, most are in pdf format which can be read with Adobe Reader, which is a free app, just google it (it might be on your system already), as far as books goes there are many free sites available through google also..
Here I saved you the trouble
Adobe Reader:
http://get.adobe.com/reader/
NOTE: just be sure to uncheck the toolbar box on the screen....you dont need it....unless you really want it
Ebooks:
http://www.free-ebooks.net/
There are many more
PS. Welcome to the forum..
« Re-install Ubuntu? | New 1012 owner »
