Default Wireless Problem - 03-30-2010, 07:16 AM
Hi All,
New guy here. I've got a Mini10 and am having a heck of a time with the wireless part of it. I can connect to some networks, but not all, and not even my own. I don't get it, I guess.
My kids got me a Belkin wireless router so I could surf out on the patio, and I set up the wireless network according to instructions. Here's the rub. I can connect to my neighbor's wireless pretty good and can surf, but I cannot get anyplace on my own network. My visitors come to my house and can connect to my network. My daughter even connects to it with her phone! But my dell won't connect to it.
It LOOKS like it's connected. When I mouseover the little bitty TV set in my system tray I get a small popup that says (Wireless network connection (name of network)
Speed 54.0 Mbps
Signal strength: Excellent
Status: Connected)
However, I can't go anyplace on the net and cannot check mail.
What am I doing wrong? As I said, I can connect to other networks, like my neighbor's and like in public areas and such. What's up?
Thanks in advance for any help on this.
Guinifi
Default 03-31-2010, 12:13 PM
Wow. I guess this one's got everyone stumped, huh?
Guinifi
Default 03-31-2010, 02:03 PM
Does your router show that the Mini has been assigned a network address? Which OS are you running?
I recall that when I first got my Mini 9, I had a similar issue with only the Actiontec router in my home. It worked most anywhere else. I replaced the router and it worked much better - later I replaced the network card.
Cool 03-31-2010, 04:06 PM
if you can go to the command prompt and type in "ipconfig/all", that should display your current settings, look at where it says IP ADDRESS..what is listed there?
PS. This only for Windows..and if you are on Windows 7 look where it says something about IP4v..and the addresses listed there..if you are on other OS's?..Good Luck...
PSS. Welcome to the forum..
pablodiablo696996's Avatar
Default 03-31-2010, 09:46 PM
Its not your computer with issues. Its your router. I have a Trend net router and its very picky. My mom in law router is Linksys and runs fine.
« plse help!! Integ webcam driver dell insp no inf | Fleeing the dark OS »
