Thetony Thetony is offline
Thetony's Avatar
Default flash drive - 03-26-2010, 10:16 AM
i just got a toshiba satellite L455 yesterday and figured i wouldn't need the nbi.img burned on my flash drive, is there a way to remove it?
|LOCKERZ.com invites, PM me if you want them. Its a rewards site that gives you points by watching web shows and logging in.|
I hope I can find a new mini 10v.....
Cool 03-26-2010, 02:49 PM
just format the flash drive...
R850R R850R is offline
Default 03-26-2010, 03:26 PM
ditto...you can use disk utility to format
Mini 10v (Black) - BIOS A06 - Mac OS X 10.6.0 - 1GB RAM - 320GB HDD (7200 rpm) - NBM via USB - NBI (ending with 51) - Legacy Off
Had a happy 10.6.6 machine and updated to 10.6.7, but no love...maybe I'll do a vanilla install...but probably not.
Thetony's Avatar
Default 03-27-2010, 12:35 PM
i did format it but it the capacity to 47 megs when the card was one gb and totally screwed my card
Cool 03-31-2010, 02:48 AM
you can use this utility....when you run it you will see and button that says something like RMPrepdisk you will get a screen like below..just format in which ever format your want, I suggest FAT32 or NTFS..make sure you check it off so thats its bootable when you are done, maybe click on CLEANUSB to erase everything, then run it again to make it bootable for whatever your want
link:
http://rapidshare.com/files/36803054...SB_0-2-3_2.exe
WisconsinPlatt WisconsinPlatt is offline
WisconsinPlatt's Avatar
Default 04-07-2010, 09:08 PM
Nice utility. A few hoops to jump through for a download, but looks useful. Thanks for posting.
Dell Mini 10V - Obsidian Black - 2GB - 40GB Intel SSD - Bluetooth 2.1 - Razer Pro|Solutions Mouse
Current OS: Windows 7 Professional
« Help identifying Mini 10 vs. 10v | Already own Mini 10 - would like to dual boot Osx and windows 7 »
