a53ng a53ng is offline
Default need help on reinstalling win xp - 03-25-2010, 01:01 AM
after fail installing dual boot os x, i lost my xp now. I practically give up on making my dell mini hackintos now. Can someone help me installing xp back? the bios doesnt detect my extrenal cd room, There is no usb option either when i plug my cd room. Im thinking to use my USB flash 16 gb to install xp, but the software links i found here was no longer available.
Today is just not my day
Default 03-25-2010, 01:05 AM
Since you were running OS X, you may have turned off "Legacy USB" in the BIOS. Re-enable it.
Default 03-25-2010, 02:23 AM
legacy usb is always enable, USB wake is disable tho.
Cool 03-25-2010, 03:20 PM
Here is a utility to setup Windows from USB
link:
RapidShare: 1-CLICK Web hosting - Easy Filehosting
lauriem04 lauriem04 is offline
lauriem04's Avatar
Question Broken link - may be what the OP was referring to - 03-25-2010, 03:57 PM
link:
The above link is not working - all I get is a pop-up stating that "This file is copyrighted and may not be distributed without permission of the copyright holder." It then tries to redirect me to another site to download movies.
Is this the same program?
http://www.mediafire.com/?igwzq2qnn22
Also, here's an alternative (WinToFlash):
WinToFlash - Install Windows from usb - Home page
Default 03-25-2010, 04:03 PM
gotta check that...its a freeware utility...
EDIT:
Newlink:
http://rapidshare.com/files/368030547/WinSetupFromUSB_0-2-3_2.exe
I dont know about the other programs, I have used this utility to install Win 7 Ult & Win XP Pro without any problems, also almost 800 people have downloaded it from RS dont know why its restricted all of a sudden....like I said its a freeware utility...I think you can even get it from PC Magazines site....I gotta talk to RS about it, for now I reuploaded it and the new link is above....
« Blackra1n on mini 10v | Mini 9 - Upgrade consideration »
