Kuhnie Kuhnie is offline
Default New problem discovered - 12-27-2008, 05:44 PM
In testing my email using the installed Outlook Express 6 program the spell check is only in French! I went to tools and language and the only option is French. What can I do to remedy this since French is of no good to me. Thanks
Default Re: New problem discovered - 12-27-2008, 08:51 PM
See here for the fix for this common problem that occurs after you install Office 2007.
Default Re: New problem discovered - 12-27-2008, 09:11 PM
Thanks for the tip. I solved the problem another way, I downloaded Mozilla Thunderbird and Firefox browser. Both are more user friendly. Can I remove Explorer and Outlook Express or move them off the hard drive to the E drive? If so does the screw things up? Appreciate the help. Slowly but surely I'm getting everything added the way I want
Default Re: New problem discovered - 12-27-2008, 09:32 PM
No, you can't remove Internet Explorer and I don't think you can remove Outlook Express either, but you can ignore them and make Firefox/Thunderbird your defaults for web browsing and email.
Default Re: New problem discovered - 12-29-2008, 04:00 AM
Thanks that was what I thought but wanted top check. Yes I made both Firefox and Thunderbird the defaults. Can anyone recommed a good security program to replace McAfee?
Fallstar Fallstar is offline
Fallstar's Avatar
Default Re: New problem discovered - 12-29-2008, 04:38 AM
Here is an ongoing topic on that very question...
Which Anti-Virus for the Mini?
Default Re: New problem discovered - 12-31-2008, 03:30 PM
I went ahead and upgraded to Norton's Internet Security. I've been using Norton's for years and haven't had an issue. I never like McAfee so was glad to dump it.
« New to the forum, loving my Mini! | Transferring a program »
