bjw bjw is offline
Default 02-24-2010, 07:00 AM
With windows 7 the option "hide modes that this monitor cannot display" has to be selected in order to be able to display the correct 1024 x 600 resolution.
Go to Control Panel
Appearance and personalization
display
Change display settings - from the choices in the column on the left side of screen
advanced settings - on the lower right side
Monitor tab
Check the box for "Hide modes that this monitor cannot di splay"
1024 x 600 should now be an option for the display setIting
Similarly in XP: Display > Settings > advanced > monitor > check box " hide modes that the monitor cannot display"
mrcrysis mrcrysis is offline
Default 08-22-2011, 09:22 AM
I have the same issue here.
But the box for " hide modes this monitor can't display" is greyed out so I have no way to tick it.
Any help is appreciated.
Default 08-22-2011, 02:19 PM
that is usually caused by a driver issue. make sure that you have the correct and latest drivers, remember that most XP drivers will work on Win 7 also
  (#14) Old
Default 08-25-2011, 09:14 AM
Hi, thanks for your reply.
Which driver should I use?
Because I downloaded the 10v's XP driver from dell's site and it won't install.
  (#15) Old
Default 08-25-2011, 03:05 PM
Go here and use the tool to detect the needed driver, which is for the Intel 945GSE chipset.
  (#16) Old
Default 08-27-2011, 07:31 AM
Is there a Windows 7 or Windows XP version to choose from?
If so, which should I get?
  (#17) Old
Default 08-27-2011, 01:03 PM
If you are running Windows 7, then use Windows 7.
  (#18) Old
Default 09-09-2011, 09:26 AM
Alright, I ran the utility and it said that I have the latest driver.
So, I am thinking of using a XP driver for my GMA 950 to solve my problem.
But I couldn't find a XP video driver. The one from Dell won't install due to incompatibility. Can anyone help me find a XP driver for the GMA 950? Thanks.
  (#19) Old
Default 09-16-2011, 09:11 AM
Umm....
Can anyone please show me where to download the XP driver for gma 950?
More specifically, the one for the atom n270 chipset.
  (#20) Old
Default 09-16-2011, 01:24 PM
Originally Posted by mrcrysis View Post
Umm....
just go to Intels Web site....
BTW: the processor has NOTHING to do with the driver whether its the n270/n280 etc....
« Web Brower Key Entry Problem | which is better? »
