somms somms is offline
somms's Avatar
Default Re: Network Help - 12-27-2008, 06:47 PM
Originally Posted by thecatmac
I know I had to update my firmware for my lynksys wrt65g router to get mine to work. After I did that, I got connected!!! :mrgreen:
http://en.wikipedia.org/wiki/DD-WRT
Was this on the WRT54G wireless router? Ended up flashing DD-WRT opensource firmware onto a WRT-600N dual band draft-N router and have much more features and improved performance over the stock Linksys firmware including OpenVPN! :mrgreen:
Default Re: Network Help - 12-27-2008, 08:48 PM
The process for each brand varies, but typically you go to the manufacturer's web site (linksys.com, etc.), find the support page for your model router and see if there is a firmware update for it. Follow the instructions given there.
« VERY basic questions | Loading Office from SD card »
